Factorytalk SE and MSReportBuilder
notausp
May 2016
Americana
18
does anybody have a sample on how to create process/alarms/events/production reports using Factorytalk SE and MSReportBuilder?
http://www.plctalk.net/qanda/showthread.php?t=63354
http://www.itpro.co.uk/sites/itpro/files/documents/reportbuilder.pdf
https://technet.microsoft.com/en-us/library/dd255273(v=sql.110).aspx
I would treat this as two separate questions. The first thing to do is get Factorytalk up and running and logging your events into a SQL database. Then look to MSReportBuilder to read from the SQL database. The above are links to some resources.
Hope this helps you out.
Regards,
Thank you gclshortt!
Well, I have already done the FTView and SQL step. I'll read about MSReportBuilder and then I'll go back!
Hi! I made a successful link between SQL and FTView, my tables are good and I developed my ReportBuilder's report. In REpBuilder preview I can successfully populate my report.
The question is: how to embed my report in runtime FTView Client, without the need to open external application.
I thought it was easy, something like just put an activex, but until now can't find a solution.
In Citect its possible trough a template and Cicode passing report URL, with SSRS (Microsoft Reporting Services) properly configured.
any help would be greatly appreciated!
Posting it here on this thread is probably fine. In the future, someone with the same question will likely come across this thread, and having a tutorial at the end of it will help them no end :)
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
126
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
96
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
