Factorytalk SE not logging one processor
wes.s
Mar 2014
Northern Michigan
57
A couple weeks ago we lost getting alarms sent to one of our Factory Talk pc displays. I've been poking around trying to figure out what is wrong but I'm not getting anywhere.
I found that the plc for the problem line had a netmask of 255.255.0.0 on a class c subnet. I changed that to 255.255.255.0 and nothing good or bad happened.
On the display that is missing the alarm info, I added what it takes to look at the processor in the line next to it. The alarm and message display shows me alarms for that line just fine.
We log alarms to a sql database, my problem line quit logging 2 weeks ago, my other line is logging just fine.
The alarms I'm looking for are generated using the almd instruction. If I look at the instruction I see error and no subscribers.
Any ideas?
Hi All, I'm trying to look into if it's possible to get FactoryTalk SE to build a process log report, recording various tag values at a poll rate...
578
I am having an issue with Factorytalk View SE. I am trying to add new alarms which is requiring me to use the "AlarmOff" command in the command...
631
We are installing a PLC that is in gray area between commissioned and actively running. We have 2 log ins on the HMI, my log in and the client's...
665
Hey guys how would you approach the spreadsheet screen part? I searched and everyone points out that using parameters to display this information...
750
Hi, Is there a way to do data logging to an Access database on a PLC tag turning from 0 to 1? I know how to do data logging using FT view but...
945
