FactoryTalk SE Timer with VBA. Can I create one?
Jul 2007
Kiruna
600
Hi all,
I have an application (FactoryTalk SE & Micrologix) which requires a lot of of navigating around screens based on PLC events rather than events by user i.e button press, etc
An example:
Screen 1
Door Closed -> Navigate to screen 2
Screen2
No input recieved on PLC within 30 secs. Navigate back to 1
Input recieved on PLC -> Navigate to Screen 3
No keypress within 30 seconds navigate to screen 1
etc etc....
The transaction has to be as quick as possible with customer to prevent a bottleneck at paypoint so I want to avoid using buttons to progress through the screens.
I'm currently using VBA to navigate through screens based on a numericdisplay_change event. While this works its getting a little messy.
In addition to this I'm using VBA on a specific display to count number of characters inputted. When this reaches 6 I then hide visibilty of some objects and download value to plc.
What I would like would be to use a timer in SE/VBA engine to do the timing rather than the PLC.
Of course there is no timer control/object in VBA. Has anyone any experience/ideas on how to best achieve this?
I got your solution.
Please do no use this:
If CurrentUserName() = "PRODUCCION\USUARIO" Then
Exit Sub
[FONT=&quot]NumericDisplay1.Value is a numeric value on a screen this values comes from a tag on the plc, so you have to manipulate that tag to change the value and change your screen.
It works, I´ve been using it for more than 3 years with no problem, do not forget to cache the screen where the [/FONT][FONT=&quot]"NumericDisplay1.Value" is located, this way SE always update the value and change screen automatically. [/FONT]
I found a list of activex controls in view studio for which I simply cannot find any information on online. I don't know what they do. For example...
978
Good Afternoon , I have an older Panelview Plus and do not have the application . I'm in the process of re-doing the HMI application from...
3,922
Can someone tell me how to display a timer value when creating a screen in Factorytalk View ME?
4,138
I did not create the program but I have a weird countdown timer problem. it is user input, say it is set for 5 minutes; it will countdown to...
4,468
I am working on a new View ME project for a demonstration display using a PC Hosted version of ME Station. I would like to show a cylinder...
3,166
