FactoryTalk SE v13 Alarm as DWord
sicka
Dec 2012
Vienna
I'm trying to set alarm as DWord where each bit is individual alarm.
So far I have tryed with
DWord.0, DWord.1, DWord.2, etc.
DWord.L0, DWord.L1, DWord.L2, etc.
{Word.0}, {DWord.1n}, {DWord.2}, etc.
DWord & 1, DWord & 2, DWord & 4, etc.
What am I doing wrong?
jgTdZSy
If you are using the built-in alarm function:
In FTV, under Alarm Setup > Triggers tab > Trigger Settings: > set Trigger type: to "Bit".
In Messages tab, set the Trigger to your Dword, set Trigger value to the bit number. Bit number is 1 through 32 which corresponds to Bit 0 through 31.
are you talking about ME or SE?
I'm using SE and when I open alarm server I have only this:
For FTSE, when you create a new alarm, select Digital alarm. When you browse for the Input Tag you won't be able to select the individual bit. Select the integer (SINT, INT, DINT) tag, then when the tag browser is closed you must edit the tag reference to add the bit number.
Thank you clintm, but what is the correct syntax?
I tried with Tag_DInt.0, {Tag_DInt.0}, but this doesn't work.
This syntax works on a SE Distributed system we are working on currently:
/area::[Shortcut]Tag.bit
Make your bit work on a graphic display element first. The alarm syntax will be the same.
Sorry, I didn't told whole story. I'm using Factory talk v13, Kepware as OPC and Siemens S7-1500 as PLC. What I figured now: if I create local tag (INT, DINT, WORD) I can access individual bit (same as you can when using RSLogix). If I try this with tags in Kepware it doesn't work. Anyone have some ideas?
In FactoryTalk View SE v13, how do I get an audbile alarm/bell from the PC speakers to work? The checkbox option that was in the alarm banner...
577
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
157
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
41
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
140
