FactoryTalk Services Platform issue
jkerekes
Aug 2007
NJ
2,363
I have a customer who has installed on a server several RA apps. Such as FTView SE server 5.0 , FTView Studio, RSlogix 5000 v. 17, RSLogix 500. I've noticed that in the add/remove programs list that two FTSP versions (CPR9 & CPR SR1) are installed at the same time. Is this normal or is it a problem? I know that it's probably a good idea to minimize what stuff is installed on a FTView SE server. Ken do you know a reason for this?
Well it wasn't working well. It came to a point where the SE server had to be rebooted several times a week to restore functionality. I never knew you could have multiple versions of FTSP installed at once.
I've seen that technote. Actually in Add/Remove programs you can see the two versions installed, CPR9 & CPR9 SR1. Logix installs an updated FTSP if it needs it to run, but apparently without any warning to the user. Granted it's probably wise to limit what gets installed on an SE server computer, but still this isn't correct.
I got another technote form tech. support syaing two installs are possible. I'm still looking for the Logix release notes that document this behavior. Also what other Rockwell installs do this.
It is regarding factory talk view alarm and events server. we have a primary/secondary configuration of factory talk. we recently upgraded our processor to L75 which required logix5000 upgradation, we did it to v19.0 from v15.0 in the logix which is on secondary server. the cd also upgraded the rs linx enterprise and factory talk services platform. Now everything is working ok, except alarm & events server stating error that version mismatch on primary and secondary. In case we upgrade our primary also, factory talk SE will also need an upgrade and this all requires plant shutdown. Any other way to bring back our alarm and events server to life online?
Hi all. All of a sudden when i attempt to open FactortTalk ME Station on my Windows Vista Laptop an error box pops up stating, "The FactoryTalk...
4,010
So, I grab my ~2003 FactoryTalk View Studio software off the shelf and install it in Windows 7. When trying to run it, I get "FT Services...
4,792
Hello all, I have SE 5.10 Network Application with redundant HMI and Data Server as outlined below: Server 1 : HMI Server Primary, Data Server...
5,064
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
212
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
51
