FactoryTalk Software
Sep 2020
Peru
Hello everyone. Hope you are ok.
Currently I am doing a automation project and I made the following IAB Architecture.
As you can see I am using 2 generic server (1 principal and 1 redundant). Also this project consist of 4 different processes and to not use to many physical servers I am planning to virtualize (1 Virtual machine for each process). This is where my problem begins.
I am not so sure which FactoryTalk software to use for the virtual machines and the Clients(also 1 client for each process), I need some help with this.
Thank you.
A few questions -
Why are you using a VM per process? Why not combine each process into an application and then break the application into Areas? (I would see if this is possible solution) What are the size of each area?
For the software I would utilize FactoryTalk SE. I am unsure if FactoryTalk ME has redundancy capabilities. Then have an RDS VM for remote connection from the clients.
A few questions -
Thanks for the answer. Yes ,I use a VM per process. Each process are required to have their own factorytalkserver. Also do you have any suggestion for factorytalk that lets you make Excel reports for any critic variable in the process?.
Hello all, i want a FTView Software but i don't have a license. Is there any possible to download it for free or any one share the link of a...
626
We upgraded our systems to FactoryTalk Service Platform 6.31 and ran patch roll up from Dec 22 after software updates. We have a network...
1,463
Good Morning , Several years ago I would use Hope Industrial Monitors , with a PC , and Rockwell Automation FactoryTalk View Runtime Software...
1,746
Good Morning , I'm getting ready to take the step of retiring our Windows XP laptops. We have a number of older ControlLogix CPU's and...
35
9,523
I have a factorytalk .mer file I want to open it but i do not know use factorytalk ver?? to open it How should I do it? thanks~
2,118
