FactoryTalk View Alarm Summary Parameter Filtering
Astleas
Jun 2022
USA
Hi All,
I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary object that displays the alarm list specifically for the tag whose faceplate was called. In the global object for my faceplate, I have the Alarm/Event summary object and in the Display Filters tab I have the initial display filter set to "Tag Filter", which I've defined with the condition:
Alarm Name LIKE '%[#1]#2_Alma%'
That's the result from using the Filter Wizard, anyway. But it doesn't seem to be working. At runtime, none of the alarms for the tag show up. So my question is, is parameter-based filtering like this something that can even be done? If not (or even if so), is there an easier way to accomplish what I'm trying to accomplish? Thanks in advance for any responses.
I neglected to include this in the original post, but #1 is the PLC name/tag folder and #2 is the tag in question. Other features of this faceplate work as expected when referencing these parameters.
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
62
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
158
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
210
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
367
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
570
