FactoryTalk View I want to read and write to a database from VBA
Sep 2012
Guayaquil
Hi all!
Excuse my English is not very good
I am working with FactoryTalk View and need to read and write to a database full of data that I have. The database is made in Microsoft Access .mdb...
The idea is to interact with the database from VBA to then pass this data to the tags, the tags know how to interact with VBA but not with the database, I found a code made ​​for RSView32 but I served in the FactoryTalk View .
Please help!
I'm having an issue with getting animation to work as I expect it should work. It only seems to change when I exit the display, then come back to...
5,244
Hello, I understand that VBA is single threaded. In factory talk view SE though, since each graphical screen hosts its own VBA project, does...
4,927
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
198
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
134
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
180
