FactoryTalk View ME Alarms
jawad rasool
Feb 2012
Lahore
51
I've to develope alarm data base in FT view ME. I entered some alarms tags mannualy in the Alarm setup. then i exported that file and converted the XML file to the Excel and entered more alarms tags. then i again converted the excel file to XML and tried to import the file in FT View Me. but there was a message that the version not supported, please let me know the XML versions supported by ME 6.1
This is (from memory) how I did it on a recent project:
Create tags in Excel; cells in each row contain the respective fields for the tag.
In Excel, select all cells desired and copy (Ctrl C).
Go into Alarm setup in FT view ME, place cursor in top/leftmost cell and paste.
I recall doing this by selecting the cells of the spreadsheet, and not the rows. Experiment a little and you should get it. (Also, I don't recall what version of FT was used...).
Good luck
Hi guys, I've got problem about my Alarms services (i think), that happen after installed Visual Studio. I did a few things like, Repair : Studio...
150
Hello Everyone, Happy 4th of July to my neighbors! Is there a way to edit Alarms in Excel? The native export is XML, and there is always...
823
Hi guys! I want to read a tag name of hmi tag to create a generic alarm message. Do you know if it's possible to do? I'm using factorytalk view...
721
Doing some consulting work using factorytalk view studio and RSLogix5000. We set up alarms for the system a while ago and they work fine, as do...
3,662
Hi guys i have troubles getting the selected item properties in FTV Alarms and Events. I have this "Alarm and Event Summary" which displays my...
4,453
