factorytalk view runtime on Industrial PC (HMI)
italo2008
Feb 2009
Padova
95
Hello
I have a FactoryTalk View ME project (.apa file) and I have to make it run on our industrial PC (windows based).
My question is: What I have to download and install on the industrial PC in order to run the application? Should I install entire Factorytalk view ME?
Is it possible to install only Factorytalk view Station?
thank you
You need FactoryTalk ME Station to run the application on a PC. You don't need the full ME install on the PC.
You need FactoryTalk View ME to restore the APA and make a MER. The MER is the file that will run on ME Station. That can be done on another machine. I'm sure someone here would help generate a MER for you if needed (myself included)
Thank you all.
Now I have installed FT ME Station on HMI, I can run my application (Just one page at the moment). I didn't activate the runtime license yet, because I want to test everything before activate it.
The problem I have now is that it seems the runtime application does not communicate with PLC.
I tried, in FactoryTalk Studio, to use "offline tags" or "Online tags" ( I have also the PLC on my desk). in FT Studio I see all the online tags, but afte downloading and run application, runtime seems not to see any tag. The HMI can ping the PLC normally.
What should I look in order to solve the problem? Can be due to the fact the License is not active yet? Should I configure something on FT ME Station on HMI?
Thank you
Map your shortcut to the Runtime Tab in Communication setup. Studio uses the Design Tab Shortcut and the .MER file uses the Runtime Shortcut.
Dear all,
I have a PLC and SIS program that are simulated with the emulator.
In the other hand I added them in the communication setup and the device with the right ethernet adress (but not the right reference for the industrial pc I choosed a random panelview) in FTview studio and created a runtime. I then copied the runtime in the industrial pc.
when I open the runtime in my pc and simulate the program it works but in the industrial pc it doesn't. Can you please help me figure where the problem is ?
PS: when I ping to the adress the VM find it
Thanks,
Hi Guys, I developed HMI with Resolution of 1920 x 1080 in FactoryTalk View studio SE; and also use same resolution for Client Runtime PC yet...
559
Hello group, Thanks to Rockwell's infinite wisdom to change the O/S from WinCE to Win10, I have recently installed FactoryTalk View ME Version 12...
2,408
Good Morning , I have a customer that has an old Panelview and an obsolete 1769-L35E processer . I need to replace the HMI , and I'm changing...
1,150
I recently upgraded my version of FTView studio to V12. I am attempting to modify an older PV Plus 700, which has v5.10 firmware. I am noticing...
4,925
I have asked Rockwell (Chat only), and searched Google and the Rockwell KB, and I am still not sure what this means... [$Administrators] This...
2,832
