FactoryTalk View SE 5.10
ScottAgropur
Apr 2015
Wisconsin
Ok weird problem going on. I create an archive using application manager on the HMI computer.
I then bring archive back to my laptop to make modifications at my desk.
Both are running full Studio, same versions (5.10.00.09)(CPR9 SR 2).
However when I try and restore onto my laptop it states can not restore because it is not a valid archive.
My final goal is to update to 8.0 so for the heck of it I tried restoring the archive into 8.0 and it went. However I could not open it because I did not perform the legacy tag conversion. Which I can't do because i can not restore it into 5.10.
As a side note i did try and retore it into 6.1 also with same error of not a valid archive file.
Any clues on what my problem may be?
I've never had any reliable success with SE and backup/restore.
The only thing that works is to create a new application on the target machine, and manually import everything.
FTView is just garbage.
I have this issue when the project is created with a different patch version than the software I am trying to restore with. Go to the Rockwell site and get the latest patch rollup for FTView and patch your version 5.10 This should allow you to restore the project with 5.10 to do the tag conversion. You will also have to patch any version of FTView that you want to use going foward.
That was the problem Robobob. After I installed the latest patches all worked fine.
Thanks for the info/help!!
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
60
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
63
228
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
153
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
208
