FactoryTalk View SE confirmation pop up display
acdraindrps
Mar 2015
NY
The customer wants a display to automatically pop up when a button/numeric input on the HMI is pressed, and ask something like "Are you sure?" With buttons Yes and No. No button would just revert back to previous display, and yes button would allow the original button that was pressed' operation to be performed (such as turning on and off a pump or changing a numeric input like a heater set point) as well as return to the previous display.
I would like to stay away from VBA, as I don't have any experience with it - but am not totally opposed if its something as simple as a few lines of code. Sadly, this might be the only way to achieve what I want to do?
Any help with the matter is greatly appreciated.
I'm running FTViewSE and RSLogix5000 with a 1769-L33ER controller.
What version of SE? Version 8 has that functionality built in. Otherwise you'll have to make a popup screen that displays when a button is pressed for example.
The runtime license FTViewSE is version 8, I am programming with FTView Studio SE release #7.
The help is greatly appreciated.
Please find the attached PDF helpful for an overview of changes and features to 8.0 that I put together and took screenshots of.
That is available in Version 8.
The button confirmation (built-in) only works with regular button's (the ones with actions), and only when the action is configured to a direct tag write.
You can't develop version 8 applications with version 7.
If you have 7, you are going to have to roll your own.
Hi, i'm trying to create a popup screen which will appear only when a certain tag in the plc is active. With ME, it'S pretty easy with Global...
18,596
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
