Factorytalk View SE Data logging
JeffM93
Mar 2018
Ontario
Hey Guys,
I'm somewhat new to Data logging so try to bare with me. I'm trying to setup Data logging in Factorytalk View SE to log to my SQL database. I have created the 32-bit ODBC system DSN. Created the datalog model in FT View Studio and selected ODBC and it created my tables fine (Float, String, Tag). I chose Login required. I also setup a File backup path. With that being said, when I use the command DatalogOn- It will start the Datalog model without any errors, but will only log to the backup path. It isn't logging anything to my SQL DB. I thought it could be the firewall blocking it so I created a rule to allow connections through the specified port. SQL is also allowing Reading/Writing.
Let me know if you guys have any suggestions. Thanks!
I already have it setup like your picture above. What is throwing me off is why its logging to the backup path but not to the SQL DB.
Yeah I'm using both Windows & SQL authentication. TCP is enabled. I made sure the port is open in the Firewall. And yeah I'm using SQL Server 2014 32 bit
Does the login account actually have SQL rights to manipulate the database? I just spent two hours banging my head against that one here; created a new database for Ignition, and completely forgot to give the Ignition DB login rights to do anything with it.
/sigh
yeah im absolutely dumbfounded.. lol. Spoke to Rockwell and of course they have no clue. Is your SQL on a local or remote computer
Hi, I'm trying to connect with an HMI on one of our machines at work. I have applied the correct pathway to the plc, via the FT Linx communication...
3,143
I have Factorytalk View Studio local edition installed on multiple machines. Every once in a while the data logging locks up and pens don't update...
1,970
Hi, Is there a way to do data logging to an Access database on a PLC tag turning from 0 to 1? I know how to do data logging using FT view but...
946
Hello all, Data logging in factoryTalk view has stopped suddenly, i cannot able to find the reason. Then i tried creating new datalog models...
1,604
I am currently using a FactoryTalk program to log data and display a trend on one of my machines. I have it all working, the question i have is if...
5,641
