Factorytalk View Studio Data Log Issue
wes_h_13
Dec 2010
Lloydminster
I have Factorytalk View Studio local edition installed on multiple machines. Every once in a while the data logging locks up and pens don't update anymore. The only way I have found to fix this is to delete the data log folders and then relaunch the application. Computers all had plenty of hard drive space available. Has anyone else ran into this? If so does anybody have a fix? Please see pictures for datalog configuration.
The configuration for the Datalog looks ok. Have you opened the Datalog to see if the data was still being logged? You can open the log files in Excel. You won't see the data, but you can see the entries for the tag name and the time.
One thing to note is with the On Change setting, if the data isn't changing, then you'll just have a flat line in the trend window. Can you attach screen shots of the trend configuration?
Have you used the DatalogOff and then DataLogOn commands to stop and restart logging?
OG
When I look at the logs it appears the data is still logging. However Factorytalk View studio trends do not update with any history. Trend clears whenever I change a screen.
I use the datalogon function whenver the application opens. Howver I do have a macro to set datalogoff on shutdown.
I have tried toggling datalogon and off to fix the trending but this didn't appear to work either.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
134
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
261
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
698
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
626
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
460
