FactoryTalk View SE digital alarm on a tag in Kepware OPC
Mar 2015
Mariupol, Ukraine
71
Hello dear experts!
Please advice me how to generate a digital alarm in FT VIEW SE A&E by one bit from a tag in KepwareOPC where this tag is a word of Data Block in S7-300 Simatic PLC? I have approx. 800 tags WORD type in Kepware and each bit in these words must generate an alarm in FT. I don't want to create 12800 bit tags in kepware. When I access to Control Logix plc I can create an alarm with address tag.n, where n is a bit number. But in Kepware and S7-300 it' s impossible.
Best Regards, Oleksandr.
I also tried to use in A&E alarm input tag a mask for example [kep_opc]wtag & 4 to generate an alarm when bit 2 = true in word tag, but it doesn't work.
Maybe someone know can I use a mask in A&E alarm input tag definition?
How can I log Digital events such as valve open/close, auto/manual pushbuttons in FactoryTalk View studio.
2,830
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
