Trying to create a global object that will use parameters/parameter files. The object will be for a transmitter that has different settings for alarms. HH, H on some, L & H on others. Wanting to have an expression that will ignore the HH if it doesn't exist for the transmitter.
I can create a global object where I manually input each alarm and just put a value of 0 if it doesn't exist, but just trying to think of a cleaner way if possible.
Reference
1 - Existing RSView 32 being upgraded to FactoryTalk View SE and needing to keep the structure of having HMI tags and not utilizing direct reference tagging sadly.
2 - Programming changes for the controllers will be minimal.
