Factorytalk View SE memory tag to PLC tag
Udunit
Mar 2014
Woodstock, Ontario
33
Is there a way in Factorytalk View SE to transfer a memory tag to a PLC device tag? I have a VBS using a memory tag that I need in my PLC and had much trouble with the VBA and don't want to kick at that hornets nest again!
Could you share how you were able to achieve this. I've tried using the derived tag way but I'm not sure I have the proper syntax.
Yes derived tags are the way to go, I have two OPC servers attached to my FTview SE server and that was the only way to pass data from OPC1(clarinet from videojet) to PLC tags under rslinx enterprise.
Everything was done in FactoryTalk View. First thing I did was create a derived tag file in Logic and Control (see attachment first). Second I created the derived tag name and used the tag in the VBA (see attachment second). The tag name for my purpose was [Lesaffre Flour]TempRecipeName and the tag in the VBA is TempRecipeName. Finally is enabled the VBA in the sever (see attachment third). This worked for what I needed to do. Hope it helps!
Sorry, that was supposed to say enable the derived tag, not VBA, but whats a post from a Canadian without a good ole "sorry" in it! :ROFLMAO:
I have this hardware 2711P-T15C4D8 Running FW 6.1000.9 (CPR 9 SR 4) talking via ethernet to a controllogix PLC I have an FT application that is...
17
8,262
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
126
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
