Factorytalk View SE safe shutdown
crawler009
Feb 2012
Planet Earth
239
Hi guys
how do you manage the shutdown of the Factorytalk View SE runtime when the UPS for the PC/IPC is running out of power?
Right now the UPS is sending Windows the shutdown command when the threshold is reached, so it shuts down Windows safely. But Factorytalk is not shut down safely (i checked and the shutdown macro wasnt run).
Do you know if that could corrupt the diagnostic list, file datalogs or sql entrys?
I could easily monitor the connection to the plc from FTV, and after 5 minutes (or whatever) of connection loss shutdown the HMI application.
But is that something you guys do? Or do you thrust FTV that nothing will happen on a forced close?
Best regards
crawler009
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
33
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
221
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
189
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
130
