Factorytalk view SE Security
hamzkh
Aug 2013
Auckland
22
Is it possible to make a numeric input invisible on SE client depending on what user i have logged in from. For example if i login from user1 i can see the numeric input but if I login from user2 then it is invisible.
The main aim is to enable only one user to change the values.
Any help please??
Yes, you can. By right clicking on the numeric input, you can select the Animation menu, and then visibility. In the expression editor, you can use the CurrrentUserName() function to limit visibility as you desire.
I tried it, but its giving an expression error. What should I write in the expression E.g. my username is userone.
I found another way.
CurrentUserHasCode()
If you want to show a user with security code A then write CurrentUserHasCode(A) in the expression
Hi Guys, Please, how can I apply FactoryTalk View SE security code on a Button object? I tried 'CurrentUserhasCode' expression with Visibility...
2,281
I have asked Rockwell (Chat only), and searched Google and the Rockwell KB, and I am still not sure what this means... [$Administrators] This...
2,832
Long time user but I can't seem to find the answer to this problem. I'm trying to set the the visibility animation of a momentary pushbutton...
2,450
Hi, Gots a few nice friday evening questions. On a PanelView Plus 1250 Runtime version 5.10: - How does one exit the runtime without using a...
3,219
Hi, I am looking for direction on how to get the Factorytalk View Studio Site Edition 8.00 Runtime Security users, passwords and levels (A-P) on...
3,272
