FactoryTalk View XY plot disabled
khordin
Jul 2011
Waterloo
Hi all,
Does anybody know why XY plot option could be disabled in the new trend properties for a new trend in FTView? I ran out of ideas...o_O
I've broken the wall! Once I added pens and re-opened the properties dialog (just Applying is not enough), I got the option enabled! Thanks everyone who looked.
I know this has been a long time, but did you get the XY plot to work correctly? In FTV 9.0 my Y axis pen does not move on the x axis, only in the Y direction, even though the X axis pen value increases. What am I missing? It used to work...
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
44
223
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
195
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
139
