FactoryTalkView ME Read Tags from ControlLogix
pr_wainwright
Jun 2011
Stockton on Tees
109
I have a ControlLogix L61 CPU with an Ethernet Module & some digital I/O connected to a switch and then connected to a PanelView 6 Plus HMI. I can get online to the PLC via ethernet & I can also connect to my HMI via ethernet no problem. What I want to do is from FactoryTalkView ME be able to browse tags in the PLC (online) or project (offline) but I can't figure out what I need to setup in FactoryTalkView ME?
Any help appreciated.
Paul.
Have you set-up your shortcut on the communications tab?
Also, on the comms tab you can set the path to browse to the offline project.
Hope This Helps
Bob O,
Thanks for the reply. I will try your suggestion when i return to work. I read somewhere that RSLinx Classic had to be used to communicate between RSLogix 5000 & FactoryTalkView ME project. On the communications tab in FactoryTalkView ME the RSLinx is RSLinx Enterprise. Don't know if this makes a difference.
Paul.
I just converted an existing application from RSView32 to FactoryTalkView SE. In RSView32, the Datalog was made in a *.DBF file. There was...
84
Hello Friends I have 2 languages in my app, en-US, es-MX. I need to send CurrentLanguage to PLC, I am trying with Macro in Global Connections...
184
What is the gold standard ( hoping there is one )for converting ME alarms over to SE? I've been using the RA Knowledge Base method of creating a...
740
WOW. This one still has the low resolution graphics from the 1990's at about 10 times the price. just FOUND OUT Automation Direct Brix can Run...
18
3,111
Hi guys, Is it possible to automatically generate PDF Report of Trend and Datalog in FactoryTalk View SE v12? If YES, Please, how?
684
