Factoryview Studio
rlasseigne
Jul 2007
Texas
I am looking for some help creating a trend in Studio ME, can anyone suggest a site that might help me. I would be looking for a manual or some kind of online tutorial. Thanks in advance.
Richard
Go to Menu Objects->Trending and select Trend. Then draw it in your display and double click for properties. There you can change a lot of parameters (see hep).
Then, in your project tree you have to create a datalog in "DataLog Models" with the tags that you want to trend (this is for logging historical data, if you want only real time data, this is not necessary). When the datalog is created, go to your trend display, go to propertes in your trend and in the pen tab select your Datalog in the "Data Log Model" Combobox. Then go to Connections tab and add the same tags that you added in your Log Model (with this you make that the tags tending are the same of the model tags). After that, return to pen tab and you will see the tags added in the list, so then you can change color, caption and the parameters you want.
In a ME application you can't create big historics logs as an RSView32 or FTView SE, is only for a few points, for example 1000.
I want to use a GOTO button to display a screen when it is pressed.In other words I want to use a function key(F3) to go to screen 6 when it is...
1,926
Does anybody know how to read or import RA FactoryTalk View v5.10 data log files into Excel? Although the file is a txt file it is not human...
4,357
Hi, i am new to this form and this might be a silly question. but i wanted to clarify this sentence i found in FactoryTalk Documentation. >>> •...
338
Hi, So first off I don't think I really belong here as my experience on this is pretty much 0. Also I don't think my question really pertains to...
1,313
Hi, guys, how can I find the location(s) of the tag in FactoryView? E.g. we know there is a tag “pump_on.0” in logix5000 is connected to the...
1,686
