fail safe PLC & A class instrument
elkawafi
Aug 2002
27
Hi Every body
I would like to ask you for a help on the following:
1) what does it mean by fail safe & fail safe PLC?
2)what are the new regulation of A class instrument (instrument that cause the ESD for the plant) and how often it is required to do reqular maitemance for them. In addition where can i find the any useful documentation
3)the fire and gas system is it consider to activates the ESD or it just for alarms to operator.
Your help is highly a preciated
Thank you and best regards
Elkawafi
I "assume" ESD means electrostatic discharge, if so there is a magaine specific to that: http://www.esdjournal.com/
Tutorial on ESD: http://www.midwestesd.org/aboutesd.html
This describes the term Fail-safe: http://en.wikipedia.org/wiki/Fail_safe
This link will take you to Siemens support for the S7-400 Fail safe plcs, you can get manuals etc and should be able to see wiring examples etc: http://support.automation.siemens.com/-snm-0135109872-1116758784-0000025094-0000013271-1119614215-enm-WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=cseus&aktprim=0&startNode=4000024&nodeID0=10805207&basisview=4000003&viewLevel=6&wttree=cs&foldersopen0=-175-176-177-228-298-324-&jumpto=324
Hi every body How the fail safe signals bypassed (for maintenance or start-up)without affecting the program safety? Could any body help me for...
5,126
How fail safe mode in level transmitter works? customer requesting for fail safe mode when the transmitter got any issue or power loss on the...
1,003
After updating TIA selection tool I was notified that my PLC was now under "predecessor". It was not valid if the "fail-safe" operation was...
1,965
My employer is in the habit of applying a roller limit switch on a P&F chain overload in a non-fail-safe manner. The LS is only operated if the...
1,362
I read the WinMOD manual that simulate fail-safe IO is possible with A756. But actual not, here is my configuration, anyone successes with...
1,518
