My employer is in the habit of applying a roller limit switch on a P&F chain overload in a non-fail-safe manner. The LS is only operated if the spring-loaded cat-drive mounting sled moves enough to indicate an overload condition. If the LS is adjusted improperly, or if the wire is cut, or if the LS arm is missing, etc., there is NO protection.
Other vendors I have worked with apply this LS so that its roller is always in contact with the floating striker, until such time as an overload causes it to roll off the end, stopping the motor.
I don't know how much of a stink to create, but I really wish we would stop this practice. Anyone have a similar situation, or comment on the safety aspect?? I feel like there is no regulatory standard covering this. Thanks for your input; I realize it's not truly PLC related, but certainly controls-related.
Cid
Cid
