failed channel
ag.pascual
May 2011
jeddah
hi,
i'm new to plc.
we got tsx 3721 micro and the tsxaez802 8input analog module had burn-out dc/dc converter,so i replaced it with new one.After power is on it gives me I/O error and i saw in hardware configuration the new aez 802 has not been known and and indicates "failed channel"and saying empty on the slot/rack no.8
Is the card hot swappable?
Did you hot swap the card?
Any chance that a fault has turned a low level DC analog input into a higher voltage "destroyer" signal?
Did this failure condition occur with a change in field wiring or configuration?
Sir,what do you mean by" hot swap"?
the problem occurred without any external intervention or changed in field wiring.
and the " module is missing or different from the one configured on this position" appeared when i installed new TSXAEZ 802 module on the same slot.
thanks...
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
152
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
57
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
203
I'm getting the Dreaded "Failed to go Online with the Controller, Unable to Open Connection - All Connections may be in use" I suspect an...
510
234
