failed to copy alarm.dat
briana banks
Jul 2005
242
Hi
Using RSview SE i wanted to copy my project to another
computer.when i start copy my project directory
it fails when it reaches alarm.dat
it keeps saying that another application is using this file.
i tried to shut down rslinx but no use.
what to do ?
Thanks.
You need to use the proper utility to move files between computers or to copy/backup your project, since RSView SE entangles itself in your operating system very thoroughly. Try this utility from Rockwell (if you are already using it, ignore this comment):
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/6ead4531e08f2074852569bb007630d5/cd44870c2672045385256f5b007c1bef?OpenDocument
This is very likely to be your troublemaker by your description of the problem.
If you are using the proper utility already, try stopping all alarm logging and alarm services from inside RSView SE via the commmand line using the AlarmLogOff and AlarmOff commands. Occasionally this causes trouble.
Finally, you can stop all Rockwell services (look for "services" under administrative tools in your control panel). This will definitely stop all processes using RSView SE files, but this is cumbersome and you can mess things up if you are not careful - last resort only!
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
126
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
50
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
185
I'm getting the Dreaded "Failed to go Online with the Controller, Unable to Open Connection - All Connections may be in use" I suspect an...
490
220
