Failed to Set System Time
jonfarrugia
Mar 2008
London
130
I am using a panelview plus and I am using the PLC system clock to sync the panelview time. For some reason I keep getting a panelview error as "Failed to Set System Time" When the HMI tries to set its own time every minute.
I've attached the global connection tags from the HMI. Those tags are populated in the PLC using a GSV instruction.
All my previous HMI's are done the same way without an issue. I just can't understand why this one is giving me grief.
Did you type the tag or did you find it Via the Tag button and link to the PLC Tags
Shouldn't you have :: before your Tag or expression
I see your "Remote Date and Time" Trigger is using the same Tag as "Remote Minute". Try using a separate trigger Tag, maybe a bool instead of an analogue.
Not the first time I've done this and never had this happen before. I run BootP, can see the MAC address of the 1756-ENBT, select it and enter...
5,444
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
124
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
48
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
184
I'm getting the Dreaded "Failed to go Online with the Controller, Unable to Open Connection - All Connections may be in use" I suspect an...
489
