Failed to set an IP using BootP
prinejr
Mar 2012
Bakersfield, CA
Not the first time I've done this and never had this happen before.
I run BootP, can see the MAC address of the 1756-ENBT, select it and enter the IP address. I get the following message on the ENBT card: "IP address/mask/gateway config invalid". I'm using BootP version 2.3 and my ENBT is running firmware 6.002. Any suggestions?
Must have been the jet lag. I figured it out. Thanks
Have you done checking your network settings on the BootP.. The gateway, and subnet mask must be same as the network your PC and the 1756-ENBT connected to. If not, then change it.
I experienced the same...heres what fixed it...
In BOOT/TP go to Tools > Network Settings...Make sure your Gateway and Subnet Mask makes sense...My Gateway was not set to all zeros...Once i corrected ReRan the BOOT/TP...All is good...
I am using a panelview plus and I am using the PLC system clock to sync the panelview time. For some reason I keep getting a panelview error as...
5,000
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
123
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
46
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
182
I'm getting the Dreaded "Failed to go Online with the Controller, Unable to Open Connection - All Connections may be in use" I suspect an...
487
