Very cool that we have hydraulic discussion.
Who cares about spool feedback? The above was to eliminate a manual flow control to save time. The manual flow control doesn't compensate for viscosity(temp) changes, right.
If you need closed loop, screw the valve. You need feedback from the actuator that you are driving. Close the loop and all will be cool.
Here's my real world:
Do you have any idea of how many machines are being produced, utilising a Vickers controller-card + Proportional Valve?
I have one client who ships 300 machines/year.
Now, what happens: They need the greatest possible speed but they also need repeatability. So what happens?
Well their PLC has a quadrature ($$$) encoder input.
They drive a digital output to tell the proportional valve to go in the positive direction at high flow-rate. When a certain trip-point is achieved, they switch to a lower velocity which involves the Vickers built-in ramp generator. They arrive at target position and they switch the valve off before rapidly returning. Minimum $2,500 for this valve + card.
Now, RPi Pico...$7
LS7366 Quadrature decoder/counter (SPI)$5
LM358 to convert PWM to analog +/-10v $1.00
Suitable PSU $20.00
24vDC bang-bang valve $150
The components listed above could easily generate a closed-loop trapezoidal profile and drive the arm MUCH more smoothly than the Vickers dumb solution.
But hey, let's just do what we've always done and then we can go watch football or some soap operas.
It's effed-up
Craig
