I don't know the application you have but going back to the late 90's we used some propotional valves with built in pid controllers, we did not use the PID that was done in the PLC but essentially these units pulsed the air supply you could here them they did not have to be really fast and it was essentially a 5 port valve centre off (center for the US before we get hundreds of posts on spelling). These worked very well on a number of in-line temperature control. Indeed I did some mods on an existing machine that used a servo drive on a sealer, the base holding the packs was sent up towards the head, stopped a given distance before the sealing head to inject gas into the packs then carried on to full compression for sealing & cutting. The servo's were expensive, actualy were more troublesome than the original pneumatic system on the early models, I put back the cylinder (a very large one) with a LDV (I think it's called) basically a linear encoder type unit then the program was pretty simple to run at full air til gas position minus x mm then an analogue flow control driven from the PLC slowed down until position reached, the final compression stroke was full bore. this proved far more reliable in regards to the wet & harsh environment, cheaper, the only thing was the cylinder needed regular maintenance i.e. seal replacement & greasing perhaps once a year. these machines ran for over 20 years with no problems so in this instance the old tech was cheaper, far more reliable & easy for the Maintenace teams to understand.
