Wago 750-632 Proportional valve module
ganutenator
May 2002
kansas
1,440
Anyone have experience w/ this module/application.
I have been tasked w/ using this module to control the flow of chemicals w/ a iQ Tesla proportional series control valve.
plc: Wago 750-862
module: 750-632
0.047 or 0.062 orifice size valve.
More to follow on the application details.
Tips, tricks, land mines?
Using mode 5 on the card. 2 valves (1 coil on each, unidirectional).
Do I need to add another pwr supply to the rack? most likely.
I am confused. 1 coil on each valve sounds more like an ON/OFF control not proportional control. that usually requires a motor of some sort - electric or air powered.
I have not used the module but there's a library available from Wago that may make your life a bit easier.
The name is: "WagoLibMC4_Solenoid" that uses your current module (750-632).
You should be able to configure and control the module via the library instead of using Wago-IO-Check.
Hope this helps.
I had a quick look at the specs & it looks like it works very much like some I/P units I have used, basically it appears that although there are a number of modes the most common is as follows, putting a setpoint into their function block then works a little like a PI controller, the outputs pulse the mark/space ration changes as it approaches set point, so in effect, assume 0 % a setpoint is posted in the function, one output will put a signal to drive the valve open, as it approaches setpoint the output pulses slowing down the rate of climb, the same goes for reducing the valve open percentage, it is not completely clear but on the surface it does appear it could work this way. I'm assuming it is some sort of 5 port centre off valve it controls in other words can hold it's position.
There seems to be some standard functions in the software similar to say a PID function.
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
84
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
122
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
355
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
345
Hi, I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange)...
899
