fanuc 18i tb control
Lherman
Mar 2011
Indianapolis
Not sure if this is the right place for this question but.....Ihave a GE FANUC 18i-TB control on a Hardinge Elite 27MS.My question is in regards to rapid traverse.The turret travels at roughly 200 IPM from home to spindle.I have the parameter number i just don't know what the numbers should be.Right now X,Z & E are set at 24000.What does that mean?I'm just trying to increase the rapid traverse.Thanks in advance for any help.
By default the 24000 would be encoder counts but this is controlled by and generally 'scaled' by the machine builder. The Hardinge manual should give you that information.
You could calculate it by replacing 24000 with 12000 and measure the speed again.
Hello everyone, I am new to the forum and new to PLC's and was wondering if anyone in here is familiar with FANUC and or TOYOPUC Plc's?
1,709
I have been trying for some time to connect an read spindle load off a Johnford Lathe - I have installed the required(according to GE FANUC)...
3,526
Hello I am trying to find out what parameter I need to enable use of the real time clock for macro programming. The machine is a Muratec MS6 Lathe...
25
15,252
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
38
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
123
