weston
Has anyone had a problem with GE Fanuc 364 cpu not coming up in run mode after power up? The hardware config is set up correctly but will not auto run. Its because it is in stop fault mode with:
Loss of daughter board
Program block checksum failure
Currupted Memory
I can not figure out why?? Go online with it clear the fault table and manual put it in run and it runs with a problem until power is cycled.
That is one 364 doing that. I have 2 others that ethernet ports do not work and a 374 that sometimes flushes the program after being powered off and sometimes doesnt. with a brand new battery in the power supply.
Any help is definitely appreciated. thanks in advance
Currupted Memory
