Hello Guys
I have an 1756-L73S Controller with a Fanuc Robot mapped as follows:
- In 1756-EN2TR Slot 2 the Fanuc Robot is defined as an Ethernet-Module R01_R1 with an IP 192.168.1.16
- In 1756-EN2TR Slot 3 the Fanuc Robot is defined as an Ethernet-SafetyModule R01_R1Saf with an IP 192.168.1.16
- Both modules have the same IP address.
Physically connections:
- Slot 2 and Fanuc controller are connected to ethernet switch 1.
- There is a cable connecting ethernet switch 1 with ethernet switch 2.
- Slot 3 is connected to ethernet switch 2
I tried to put both R01_R1 and R01_R1Saf in the same slot, but I have an error because both components
have the same IP address, do you guys know how could I fix this?
