Fanuc programing
Jaybird61
Aug 2012
SD
26
New to the site but what I have seen, I think I am going to like it here. Heres my question, I am working with a Fanuc series 90 micro and proficy machine edition for programing, my problem is when I install a off delay timer I cant get my logic equal. It seems to work but what am I missing?
With the Series 90 Micro product line you MUST put at lease one #ALW_ON (%S7) contact some place in the logic to get Logic to be Equal.
Just a quirk of the beast.
RussB, you sound like you've got a lot of GE experience, I was hoping you could comment on this:
I created some low level UDFBs (call them a,b,c,and d) for conveyor and stop control, and created another UDFB (call it X) with multiple instances of a,b,c,d as members. I debugged an instance of X just fine, then created another instance called Y, changed the I/O references, and then experienced crazy behavior. It was like X & Y both shared a common instance of a,b,c,d. The I/O state for each instance had to match for anything to work (ie, part present on both X & Y conveyors had to be true before a stop would actuate and then both stops on X & Y would actuate). Is this something beyond the Proficy (v6.5 on RX3i) capability or did I do something wrong? Thanks in advance, Jeff
This would be better as a new topic.
Are you passing by value or by reference?
Are you only using standard timers - TP, TON, TOF?
Do you see items in the variable declarations like CallInstance.X.a.Input?
New Topic, maybe.
No, I first made a,b,c,d as members of X. Worked fine with the first instance of X, blew up when I created a second instance called Y.
Later, I did try creating unique instances of a,b,c,d for X, Y, and passed them by reference (by value is not allowed with UDTs or UDFBs) but had the same results.
No, only used standard TONs or TOFs.
YEs, everything is visible in the variable menu tree.
Sorry, that's the best I had for now. I don't have a test Rx3i, so I wouldn't be able to create the situation and test.
I can't see any reason why it shouldn't work, so there is an explanation somewhere.
Update to the latest version of PME withthe latest SIM and try it again. There were a few issues with earlier versions.
Today (09/02/12) this is Version 7.0 SIM 12.
Hello everybody, i hae a ge fanuc 90 30, logic master 90 - 30 sw, the problem is that i donot know how to write the ladder diagram, when i run the...
23,320
Hello Everybody, I AM USING A GE FANUC 90-30 PLC, VERSAPRO TO WRITE THE LADDER DIAGRAM, THE PROBLEM IS THAT I HAVE AN OLD LADDER PRINTED ON...
6,626
Hi, I Am Not Familar With Ge Plc What Is The Name Of The Programing Software Used For The 90/30 Series. Thanks,
19,310
I am looking for a diagram to make a programing cable for the fanuc 90/30 series plc Thanks
2,317
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
