Ge-fanuc 90/30 Programing Software
ford
Mar 2003
26
Hi, I Am Not Familar With Ge Plc What Is The Name Of The Programing Software Used For The 90/30 Series.
Thanks,
There have been several names.
When the 90-30 was first introduced, the programming software was called Logicmaster 90. That was a DOS application, but it will run under newer operating syatems, including XP.
Logicmaster was eventually replaced by VersaPro software.
VersaPro was replaced by Proficy Machine Edition software. You might also see Proficy Machine Edition called Cimplicity Machine Edition. Proficy Machine Edition is the programming software that GE Fanuc is selling today.
You might also find references to a software package called Cimplicity Control or simply Control.
Proficy Machine Edition can import program files that were originally created with either Logicmaster, Control, or VersaPro.
If you have PLC with older firmare versions, there may be compatibility issues with Proficy Machine Edition software. None of them are severe.
Have you link where can this software free download
I haven't worked with that in several years but the local dealer is very helpful. He gave me a full version that lasts for several days.
Enough to make a BU or changes.
New to the site but what I have seen, I think I am going to like it here. Heres my question, I am working with a Fanuc series 90 micro and proficy...
2,544
Hello everybody, i hae a ge fanuc 90 30, logic master 90 - 30 sw, the problem is that i donot know how to write the ladder diagram, when i run the...
23,324
Hello Everybody, I AM USING A GE FANUC 90-30 PLC, VERSAPRO TO WRITE THE LADDER DIAGRAM, THE PROBLEM IS THAT I HAVE AN OLD LADDER PRINTED ON...
6,628
I am looking for a diagram to make a programing cable for the fanuc 90/30 series plc Thanks
2,320
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
