fanuc rj3 LS file backup
bigrthanur
Mar 2007
Ohio
85
Hello,
I know this realy isnt a PLC question but was wondering where in the LS file back up i could find a list of key strokes on the TP.
What happened was a person in the maintenace staff had bent a EOAT and i looked at the alarm history and found 30 colision guards. I would like to know how this happened. I think they were jogging in the wrong cords. but cant remember were this info is located. Or if it was even an option in the older controllers.
I may be wrong, but I don't think the LS contains that info. The LS file is what the Fanuc PC software generates as far as paths, I/O, and setup parameters. You can then convert the LS into the TP files which are actually downloaded into the robot. As I said, I could be wrong, but i have never heard of a way to pull actual key strokes out of the robot.
We have a Fanuc RJ3 /iB controller. Suspect the CPU is bad. I have a backup of the System files , TP Programs , Application , Applic-TP , Error...
1,821
I never knew that PCMCIA cards and Adaptors were considered old technology . Where is the best place to purchase them. I have a Fanuc RJ3...
1,844
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
68
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
145
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
134
