Fanuc Robot no teach pendent
Holmslykke
Mar 2019
Randers
Hi, i have a fanuc robot with a R-30ia mate Open air controller, and a broken teach pendent (TP).
is it possible to disconnect the TP and make a few jumpers, log on to the controller via a browser (on a PC) and still run the program in auto mode.
If so, how? thank you for your time ;:D
I've done this with ABB robots but haven't tried it a Fanuc. ABB has the auto/teach switch on the controller verses Fanuc has one of two on the teach pendant so its more than the safety circuit.
Post your question at https://www.robot-forum.com/robotforum/, someone over there may have tried it.
I have a couple of older Fanuc pendants in like new condition that I don't use anymore, if they would work for you I would open to selling one or both.
Yes you can! Fanuc sells a plug that you can apply inside of the controller to jumper out the pendant. This allows the Estop circuit to remain ok. and you can use robot without Teach pendant.*
Good Evening , We have a Fanuc LR Mate . Our operators have the habit of grabbing hold of the robot to clear a crash , or find the witness...
4,073
Hi, folks, how are you? Is there some way to lock/freeze Fanuc robot teach pendent? Since some of our operators jumped program lines with teach...
1,725
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,557
Good Evening , We have had a problem with some broken I/O wires on a Fanuc Robot. I'm sure we just need to rerun some cables , but I was...
1,638
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,597
