Fanuc Robot P-55 with RJ Controller: Register Dump
Mackers2006
Mar 2006
Lansing, Michigan
I have a Fanuc Robot P-155 with an RJ Controller. In just sitting idle for a while, I get what is called a Register Dump. It requires a re-start of the controller. I have tried swapping some of the internal boards with good known replacements, with no good result. The fault looks like this on the robot teach pendant.
*** SERVO REGISTERS ***t(Group 1)
System Aborting (Date & Time)
[USE]System errornal Emergency Stops
<< REGISTER DUMP >>
00000000 00000000 00000000 000000000
00000002 XXXXXXXX XXXXXXXX XXXXXXXXX
Has anyone experienced the phenomina and know how to cure it?
The manual is very vague in dealing with this issue. o_O
Thank You.
Its been to long for me on a RJ. Go to Robotforum. Register and post. There are a lot of these still in service and they can help you. I will try to dig up a old manual most likely a RJ2 but would be close enough. If I find anything I will post you in both sites.
Mackers2006,
Did you ever find a solution to this problem. I am active on another forum and saw someone with this same issue and would like to try and help. With the exception of this old post I have not been able to find anything else online regarding this issue. I know this was a long time ago but I thought perhaps you may still have some insight. Any information would be helpful. Thanks!!!
Hello All. We're working with a GE 305 Pac controller with a IC695PNC001 profinet controller card to communicate with a Fanuc Robot thru Profinet...
2,297
I am having a hard time configuring my Micro820 PLC with Connected Components Workbench as a scanner for my fanuc robot. Any advice on this?
2,857
I have Fanuc R30ib Plus controller, Area Scanner and Light Curtain. The Robots can not do the process when some object blocks Area scanner and...
2,077
Good morning to all, Hope everyone is doing well. I have a simple issue, I want to view the I/O through the Robot Teach Pendant with the...
2,456
Has anyone had any experience communicating with a fanuc robot using SAP? I've got a customer that would like to send program/part selections...
1,717
