Faster Honeywell HC900 Analog inputs
s7killsme
Nov 2010
Texas
Hello,
I have an application where I need to control a valve based on multiple analog inputs. The problem I'm running into is that the only analog in function blocks that I see only run once every 500 ms, which really hinders the precision control I would like. I'm pretty new to the Hybrid Control program, but I can't figure out any other way to do this.
Is there any way to sample analog inputs faster than once every .5 sec?
Thanks for your help.
Hello,
No, 500 ms is the rate at which the Analog Input Modules update. I'm surprised that 500 ms is too slow to control a valve considering that the valve probably won't operate that fast anyway.
Even so, that Analog Outputs are 500 ms also.
There are blocks that operate faster, but not the ones that you need.
I have a 24" plotter that we print out full scale backpanels and transfer all the holes to a backpanel for faster layout and build time. Does...
1,636
Hello all, I have programmed a script in InTouch which will increment a value (lets say "tag1") from 0 to 10000 within a given interval. This...
18
5,929
We have a trainer set up and I am trying to learn function block programming to reinforce my resume. In ladder I am pretty fast. I double click...
2,081
I've got 7 Powerflex 700 drives running a varying number of motors on each drive. I have one drive that is consistently running higher speed than...
1,899
Looking for some explanation... received this instruction (see attached) from a colleague regarding how slow our laptops were at opening...
25
10,032
