fault in CP441
mahmoud turky
Oct 2009
Cairo
30
Dear all,
i have a serious problem and i hope get some help.
i have a system consists of CPU (416-1XJ02-0AB0) IN slot 3 and CP441 (6ES7441-1AA03-0AE0) in slot 4 and IM467 (6ES7467-5GJ02-0AB0) IN SLOT 9, and the CPU is broken down so i changed it with CPU414 (3ES&414-3XM05-0AB0) and it reserved slot3 and slot4 so i put the CP into slot5 but it didn't work when i downloaded the new hardware configuration (the fault led was falshing).
i don't know what execatly is the problem? but i hope get some help ASAP.
Very Thanks
Mahmoud
I'm not an S7-400 guy but since you have not had any replies, I'll take a stab at it.
You say you had to relocate the CP441 module from slot 4 to slot 5 because your replacement cpu took slot 3 & 4.
In the 300 world that makes no sense but I wonder if your software was looking at an address for the module in slot 4 and now that you moved it to slot 5, that address is invalid in the software.
Maybe someone with 400 experience will reply.
Dear Paul,
thanks alot for ur replay, and about the address of slot4, i changed the new address of slot5 with the old address of slot4 but i got the same problem.
thanks
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
88
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
98
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
115
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
159
Hi, Experts: We have 20 + years old GE PLC series 90-30 stop running (the run led not on and battery led not on) and HMI showing that "PLC has...
208
