FB251 in simatic S5
pragasan63
Mar 2014
Kapar
Dear All,
Kindly advise me how to create a program in Simatic S5-S95-U PLC to control speed of motor with frequency convertor.The input signal from up/down push button. And the analogue voltage to frequency convertor from Analogue module (at slot no 0). Voltage range 0v~10 vDC.FB251 may can be used here but I did not know how to utilize this Function Block FB25. Any one can give example of program?
Regards
Pragasan63
Hello, I'm using FB251 for outputting analog values (S5). Now, the OGR (upper limit of the output value) is KF+1000. I want do make this value...
2,391
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
200
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
185
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
321
