duckie112
Hi, Im currently using the cpu315-2dp module with an analog input. On the input is a potmeter attached to and I got the assignment from my boss to make a closed loop simulation with only the potmeter and fb41. Is that possible or not? If its not please tell me. If it is then how. So far I can only test it while turning the potmeter wich results in seeing the fb41 work but thats like me being the temperature sensor...
I need a way wich the PLC act like a heater and a sensor while the potmeter is setting the SP_INT.
Please tell me if its possible or not since my boss want to see the results on a scope >.>
