fertilizer system
Charbel
Jan 2012
Beirut
307
dear,
i have a fertilizer system consisting of a reciprocating pump and tank with a mixer,
i guess in order to protect the mixer, a low level switch needs to be included and interlocked with the mixer, to protect running the mixer in case of low level in the tank.
does the low level switch also need to be interlocked with the reciprocating pumps? from what i know reciprocating pumps are not prone to dry running.
thank you!
Charbel
Most mixers are fluid balanced so it needs to be turned off once the level drops below the mixer. This prevents damage to both the mixer and the tank. As for the pump I would shut it off at the lowest possible level. If their is another ingredient that needs mixed set up a water flush between mixes and again flush down to the lowest point possible with out running the pump dry.
Hi, I am looking for a sensor On-Off to detect the presence of fertilizer in a silo. The fertilizer is the material that they are preparing, and...
3,381
Hello, I have no training in maintaining potable water systems, so forgive me if some of my terminology is far off the mark or if I'm focusing on...
101
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
111
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
491
Hello everyone, I'm working on a project that involves controlling an array of nozzles within a CNC environment, where the nozzles travel along a...
192
