Festo FPC202
peter.walker
Dec 2003
North West
I have the need to change the program in an old Festo FPC202 plc.
The program is stored in an eprom which can not be programed via the PLC.
I have the software and cables to work with the program within the PLC ram, but would like to store permantly in the eprom.
Can anyone please explain how this is done, and what is required.
I recall a small stand alone eprom programmer being used connected to a pc.
Any further information on these PLCs would also be greatly apreciated.
I have tried many places for information on the Festo FPC202, but it has been long obsolete.
Peter
re:FPC202
Hi Peter,
I have worked on FPC202 plc's but never did an eprom backup
The book says you have to use an EPROM burner and then gives a few models, probably very old too. Posiblly we can exchange the info what we have about this processor. Give me an email.
r--
Does it look like the attached drawing?
If so, it is a re-badged Omron C20.
I believe you can re-program it using Omron software, but not sure. You would require an Omron 3G2C7-LK201E interface module. These are not cheap. To write an EPROM, you would require an Omron EPROM writer. These also are not cheap, if available.
Syswin may program the unit, if it is a re-badged C20. There is an EPROM writing facility in Syswin that you can use with a standard EPROM writer.
I personally would throw it away and replace it with something more modern.
Dear menbers,
FPC202 is an obsolete product of Festo.
I found 2 set of FPC202 from an old stock. But I do not have its programming software.
Could you inform any web source from its programming informationa can be downloaded? Or if anyone have any support available, please inform.
Kind regards.
Tanja Asad
[email protected]
Glad the site is working again... I have a customer having issues with a Festo and I have never worked with them, see below
1,326
Working with a Siemens PLC, I have to replace a bad Festo valve bank Profinet adapter with part number: CTEU-PN I am very comfortable with...
1,173
Hello Experts, Does anyone have this gsdml v2.31 festo cteu 20150503?? I've gone to the Festo website and the version that they have for cteu is...
799
Hello everyone, It's the first experience with a Festo's drives and the Festo Configuration Tool programming tool. Particularly with these...
1,510
Hi all, First post on here. I'm an automation engineer and I have plenty of experience with Allen Bradley, Siemens and Fanuc etc. Constantly...
2,969
