Festo Gear + PLC ----LOST
Robinhood
Feb 2011
Limerick
Patrick here, im in college in CIT, Cork, Ireland. Doing a project which consists of a 3-axis gantry setup, all servo actuators, supplied by festo. It was bought as a sub assembley.
Anyway, il try to give you as much info as i can. I have a Festo Plc, CPX module with 16 digital inputs and 8 digital outputs. I have 4 motor controllers ( X,Y,Z and rotation axis on the Z), They are CMMS-ST controllers, work on a CANopen based system. I am lost in how to wire these to the PLC.
I have the pin connection wire for the controllers but as regards connecting it to the PLC, i need help. I don't want to call out a FESTO engineer as they charge rediculous daily rates. Basically, can any one help in explaining why and how the CANopen system works? Do i need the system or can i hardwire it with a normal OMRON plc? Any info is greatly appreciated.
mycit.ie
Motor controllers:
mycit.ie
Whatever PLC you choose, it will need a communications scanner compatible with CANopen. This may or may not be part of a PLC. Can you post the exact part numbers for the Festo PLC components you have?
As far as Omron is concerned, if you already have a PLC post the part number. Otherwise, it would be best to get with your distributor if you are going to purchase something.
Glad the site is working again... I have a customer having issues with a Festo and I have never worked with them, see below
1,326
Working with a Siemens PLC, I have to replace a bad Festo valve bank Profinet adapter with part number: CTEU-PN I am very comfortable with...
1,173
Hello Experts, Does anyone have this gsdml v2.31 festo cteu 20150503?? I've gone to the Festo website and the version that they have for cteu is...
793
Hello everyone, It's the first experience with a Festo's drives and the Festo Configuration Tool programming tool. Particularly with these...
1,510
Hi all, First post on here. I'm an automation engineer and I have plenty of experience with Allen Bradley, Siemens and Fanuc etc. Constantly...
2,966
