Fiber Optic Card
parco
Apr 2004
Karachi Pakistan
30
Hi Every One
is there any body know about Fiber Optic Card available for conectivity between Control Logoix5555 and Siemens TI5454
reply from all would be great
thanks
Muhammad Faisal Qureshi
SCADA Engineer
Pak-arab Refinery ltd.
:rolleyes:
Good afternoon. Below is the network diagram, according to which I wanted to configure supervisor on en2tr module. Stratix is in RSTP mode, due to...
573
Greetings, I see that some network switches are specified with 100BaseFX Fiber Ports. Can I use 10GBs rated fiber Optic cable for these...
1,500
Hi all, I have a project where there is a remote control panel that's just a bit outside the range of copper CAT5 so we're going to do fiber...
2,762
Greetings, I have several control cabinets distributed across a plant and they all need to be interconnected in a ring type topology. The...
1,637
I am starting a project to upgrade our building utility system. The actual swap out will be done by outside contractor. The new system is IP...
17
4,719
