Fiber OPtic & Ethernet
duncan
Jan 2005
17
Hello,
I want to compare Fiber optic and ethernet communication in automation field.Please tell me the differences regarding application,advantages,speed etc....
Thanks....
Sometimes fibreoptic is eathernet.
Assuming you mean TP Ethernet compared to FO Ethernet, you get:
Speed - No difference, both can potentially run at either 10, 100 or 1000mbps.
Cost, TP is cheaper
Installation, TP is easier
Noise immunity, FO is just so much better, but STP or UTP may be good enough.
Distance, TP max 100m, FO max about 3km.
Doug
Fibre optics is only a medium....
The distance can be greatly improved by utilising a different type of fibre, glass compared to plastic, and changing from a multi-mode fibre to single mode.
The only con to this is the price! :)
I am starting a project to upgrade our building utility system. The actual swap out will be done by outside contractor. The new system is IP...
17
4,711
Hi All, I have done communication of Clx L63 ad Micrologix1400 through fiber optic media(Msg),but I have encounter problem. When I recycle power...
8,012
I need to convert Ethernet to Fiber-Optic. Can anyone suggest me something that is robust? The type of the fiber Cable used is 62.5/125 µm.
2,543
Good afternoon. Below is the network diagram, according to which I wanted to configure supervisor on en2tr module. Stratix is in RSTP mode, due to...
568
Greetings, I see that some network switches are specified with 100BaseFX Fiber Ports. Can I use 10GBs rated fiber Optic cable for these...
1,500
