Fiber optic gigabit network between buildings
panic mode
May 2003
Toronto, Canada
1,963
Hi everyone,
I like to do my own research but I'm in pinch with time so I'm asking for help/advice:
We have two additional buildings which are close to the main building and we
want to network them. Idea is to use Gigabit ethernet, most likely fiber optic as both
runs are a bit over 100meter.
I've seen ethernet switches with fiber ports etc. I know that distances over 60-70km are possible
with the right setup etc. We probably don't need media converter for such small distance
so standard ethernet switches may do (maybe). So far it seams that 50micron multimode cable
is way to go (should do 550m, when using 850-nm wavelength).
Any suggesttions? Are outdoors rated cable available? Can they be suspended or need additional protection? How about terminations?
How much over 100 meters?
I've seen regular ethernet perfrom very well @ lengths over 150 meters.
An advantage of the fiber is the elctrical isolation. We had wired Ethernet between buildings which would be taken out by lightning strikes of a mile or more away. Fiber stopped that.
fair enough.
if we put additional switches at the closest corners it should be about 110m plus bends, cable sag etc., longer run is up to 170m (there is corner of another building in a way).
The electrical isolation is a great bonus.
110 meters the Ethernet will function no problems. Get good terminations & 170 is doable.
Good afternoon. Below is the network diagram, according to which I wanted to configure supervisor on en2tr module. Stratix is in RSTP mode, due to...
567
Greetings, I see that some network switches are specified with 100BaseFX Fiber Ports. Can I use 10GBs rated fiber Optic cable for these...
1,499
Hi all, I have a project where there is a remote control panel that's just a bit outside the range of copper CAT5 so we're going to do fiber...
2,759
Greetings, I have several control cabinets distributed across a plant and they all need to be interconnected in a ring type topology. The...
1,637
I am starting a project to upgrade our building utility system. The actual swap out will be done by outside contractor. The new system is IP...
17
4,707
