Fiberglass Console
jgreenewv
Aug 2002
New Mexico, USA
242
Does anyone have leads for a manufacturer of fiberglass slope-top control consoles? I'm coming up blank from the usual suspects. Thanks.
Joe
Thanks for the link, Terry, but I couldn't find any fiberglass consoles, only steel. The engineer on this job is requiring fiberglass only on a 64 inch wide control console. Anyone have any other suggestions? Thanks.
You could contact Stahlin / Rob Roy (www.stahlin.com) I don't see consoles in their catalog, but a phone call could find out if they do specials. The same is true of Vynkier.
If corrosion resistance is the objective most suppliers, such as Hoffman or SCE or Hammond, have NEMA 4X stainless steel available coresponding to most products they offer in carbon steel. This may be more expensive than a standard FRP enclosure if you can find it, but would probably be less expensive than a special.
If there is another reason you need FRP then you could go to a custom fiberglass fabricator. Expect to pay a lot for tooling as well as the part.
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
Anyone know of any one that makes a small but Deep (10") Fiberglass or Stainless 4X enclosure? I only need the thing to be like 12"H X 12"W the...
1,182
How do you note that push buttons must be grounded in fiberglass enclosures on your electrical drawings?
1,648
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
995
Hello, I am having issues with adding users to FT Admin Console. I have never had an issue with this before. As I am able to add the user...
598
